CA_Traveler
Jul 10, 2019Explorer III
Turn off or disconnect the solar as it's confusing the issue. Unplug shore power and it the battery voltage is above 12.7V add a load (or wait overnight) until the surface charge is depleted and you have 12.7V.
Now plug in shore power and you should see 13V+ at the converter and 12.7 at the battery. Track down where the open circuit is located.
Tip: Measure voltage from a frame ground ONLY and not a ground wire. You might have a ground problem and using a ground wire can mask the problem. I carry a 40' wire with clips for this purpose. Any size wire will do as voltmeters draws are extremely small.
Also consider adding a battery monitor. There are several inexpensive ones available and have been posted on other threads. A AC/DC clamp on amp meter is another good option. From your description you'll see 0A into the battery.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
