bratastic's avatar
bratastic
Battery charged but RV won't run on house batteries
Hello, I have a 2007 Itasca Navion. I noticed my RV would only run on shore power. long story short, i ended up replacing my batteries and converter. I can see that converter is generating 13 plus volts (as expected) but when I test the positive across both batteries doesn't indicate that the 13 volts are getting to the batteries to charge them. Which btw I realized I have a solar panel connected which I believe is what is charging the batteries....the batteries have juice (not sure if it's just because they are new and/or if the solar is charging) but even then if I unplug from shore no juice (no lights, no pump, etc). I think I have two issues 1) converter power is not getting to batteries to charge them (I think it may never have and it's always been the solar system that I didn't know was connected) and 2) Even thought the batteries have power, they are not powering anything. Any ideas? (we also checked fuses and breakers and reset the GFI outlet in my bathroom)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
