pianotuna
Apr 02, 2015Nomad III
Hi Das,
You can get to 16 volts by direct connecting the panel to the battery bank. You would need a volt meter to monitor the process. A thermal gun to monitor temperature should be used. Stop the process before 16 volts if the battery hits 49 C (120 f).
Interstate is not dealing with a badly sulphated battery. You are.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
