RJsfishin
Jul 27, 2013Explorer
If you can't post the make model, hang a HH volt meter on the battery while its charging, and if you never see more than 13,6-8, you most likely have a single stage converter/charger, which does not charge very fast
And if you never see less than 13.6-8 when fully charged and no loads, then you positively have a single stage converter, which in warm weather can suck a battery dry in a month or 3.
A 3 stage will most times start charging at 14+ volts, and end up floating/ maintaining at 13.2-3
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
