Roads_Less_Trav's avatar
Roads_Less_Trav
Explorer II
Jun 08, 2015
Battery charging info
After living on 12 volts full-time for 8 years, I've put together a series of blog posts sharing everything I've learned about battery charging, different kinds of charging systems and the unique quirks of solar charge controllers.
We've installed a variety of systems and lived with equipment from many manufacturers, and this is all the info -- in plain language -- that I wish I'd had access to when we were designing and installing our systems and scratching our heads trying to understand how everything really worked once it was installed.
I'm not pretending to be an expert, but we've spent over 2,500 nights living off of battery power and have learned a lot in the process. In the hopes that I might help out other RVers, I thought I'd post the links here.
RV (& Marine) Battery Charging Basics
- Single vs. multi-stage charging, in depth
Converters, Inverter/Chargers, Engine Alternators
- How "artificially powered" charging systems work
Solar Charge Controllers
- How to optimize battery charging from a "naturally powered" charging system
I hope this info proves helpful to others...
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
