mena661 wrote:
mbopp wrote:
Depends on the converter and the wiring between it and the batteries. If it's a WFCO converter you're better off with a separate charger. If you have a Progressive Dynamics or IOTA converter and heavy gauge wiring to the battery, go with the on-board converter.
X2
X3
Some three stage converters are fine, some not so good.
A good converter close to the battery with heavy wire will do a great job; good converter with too much or too small wire between it and the battery won't do a good job due to wiring losses. A good charger (which will be three stage) tied directly to the battery can do a great job.
You need to get 14.4 Volts at the battery at full charge current to do the job.
Doug
