RobWNYExplorerMar 01, 2017Battery ChargingProbably a dumb question but here goes..When you have other things attached to the battery posts like an inverter, battery monitor etc. and then attach a charger to the battery posts or use the conver...Show More
BFL13Explorer IIMar 01, 2017Generally, any charging will go to run things in the rig that are on with any amps left over going to the batteries. Same with solar controllers.If you are in a hurry, reduce loads on the 12v system so more of the charging amps go to the battery
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
Related ContentBattery Chargingchassis battery charge ?AG battery switchoverCharging House BatteriesLithium Battery Charging System
