Probably a dumb question but here goes..When you have other things attached to the battery posts like an inverter, battery monitor etc. and then attach a charger to the battery posts or use the conver...
everything stays attached power will be used if things are tuned on AKA using the inverter to watch Tv or use the PC etc.. amps produced by the charger will be applied at the battery terminals the inverter , lights etc.. will use some of that power, the part not being used goes to the batteries, depending on the battery state of charge in other words, they might or might not accept everything that is left over depends on how much they need, and how large the charger/converter is
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
