RobWNY
Mar 01, 2017Explorer
Battery Charging
Probably a dumb question but here goes..When you have other things attached to the battery posts like an inverter, battery monitor etc. and then attach a charger to the battery posts or use the conver...
Mandalay Parr wrote:
Everything stays attached to the batteries. That is the proper design.
No damage is done.
SoundGuy wrote:
Not true at all ... equalize @ 16 volts and you could easily expect to see some smoke. :E
MrWizard wrote:
No Body was talking equalizing
that is a special situation, where things should be dis-connected
before doing it
BUT that is NOT normal operation
