RobWNY
Mar 01, 2017Explorer
Battery Charging
Probably a dumb question but here goes..When you have other things attached to the battery posts like an inverter, battery monitor etc. and then attach a charger to the battery posts or use the conver...
MEXICOWANDERER wrote:
I would rather put the limit at 15 volts because no automotive voltage regulator meaning alternator control is going to top out less than 14 volts unless the alternator warms up and the thermistor within the voltage divider network starts ramping control set point downward. Most Delco and Ford integral regs commonly start out in the 14.2 - 14.4 range at 25c. Motorhomes traveling long distances will arrive at set point limit for hour after hour. Hard to keep the Hatfield chassis batteries satisfied with a house battery diet and verce-visa.
