When charging (2) 12volt rv batteries through the on board converter/charger, would two honda eu2000's work any better than just using one genny to charge?
If all you are doing on ac power is charging the battery, then I'd say one 2000va generator would be plenty even if you have a 100w converter. if you are running the air conditioning and the microwave at the same time, well then ...
