Hello all, new to the forum and I have a question errr, problem. Whenever I plug in my TT, either house electric or plug on my truck, the fuse to the battery pops. It's a 20 amp fuse is this correc...
Sounds a little small. Check the size of the wire from the battery to the 12 volt distribution panel. Check the size of the converter output. I would guess it should be at least a 30. I think you have another issue. The truck isn't feeding much more then 20 at the connector. I would check the polarity of your battery. It sounds like it could be reversed.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
