Hello all, new to the forum and I have a question errr, problem. Whenever I plug in my TT, either house electric or plug on my truck, the fuse to the battery pops. It's a 20 amp fuse is this correc...
30 amp fuse is appropriate for 10AWG and typical converter output. It may be that when you are plugging into shore power the converter initialy tries to pass a greater current than 20 amps so the fuse blows. Your replacement of a 30 amp fuse may solve all your problems.
If that fuse continues to blow, replacing the fuse with a 30 amp resetting circuit breaker may be a good solution.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
