time2roll wrote:
The Honda 2200 will put 80 to 100 amps into that battery through the Magnum as I believe it is power factor corrected.
My Honda 3000 running a PF corrected 100 amp charger doing 102 amps with charger set to 14.8v (battery 13.39 and rising) showed on the Kill-A-Watt:
122.7v, 15.57a, 1910VA, 1854w, PF 0.97 (I was lucky the Killawatt didn't fry, being over 15a)
PT and others have posted about their Magnums, where they have to dial down the input amps so it pulls less VA, but then does fewer DC output amps. The Honda 2200 amps rating is the key to this.
EDIT 2200 is 15a ISTR PT posted what the Magnum Dc amps output was for what he dialled his input down to--can't remember the numbers.
My 75 amp non-PF corrected charger pulls 13.64 amps doing its 75 amps
