pianotuna wrote:
BFL13,
I dialed down to 108 amps of output, because each telecom battery should not be pushed with more than 27 amps. But for a flooded Jar I'd just leave it wide open. The jars will taper fast enough all by themselves.
Missed the point! Idea is to get the Magnum to do as many DC output amps as possible while pulling no more than 15a from the generator.
To set the lower input limit on the Magnum, do you set the input or the output?
My 100 amper pulls 15a, so that 125 amper must pull more at 125. How do you get it down to pulling only 15 and what would the Dc output then be?
