enblethen
Aug 03, 2015Nomad
The battery disconnects should be left in the on position while the rig is in use.
Shutting off the chassis battery disconnect, requires the rig to run off the coach batteries with no charging.
Use a volt meter to check battery voltages while the engine is off. Then start engine with battery disconnects both on, then check battery voltages. they should be around 13.5-14.0 volts.
Only problem is operator error by cycling battery disconnects. Leave them on while rig is in use!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
