sh410
Apr 21, 2014Explorer
A VOM will help. Put the VOM positive lead on the + post with the red cable hooked up. Put the VOM negative lead on the Black cable and if you see 12V+ on the meter then that is the negative cable. If meter reads zero then test the white cable.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
