Salvo
Feb 26, 2016Explorer
The surface charge is long gone. The glow plugs are pulling 100A for about 5 sec before the starter is engaged. As seen from this plot, battery voltage starts below 12V and drops below 10V from the 700A spike.
This is a plot of the current in the starter cable and chassis battery voltage. The data rate is limited due to the speed of the A/D multiplexer (switching between voltage and current measurements).
Data is taken on a Sprinter (Mercedes 5-cylinder) diesel with 80k miles.
tatest wrote:
That 700 is a spike fed by surface charge on the battery plates. Internal resistance in most lead-acid starting batteries limits deliverable current to 400 amps or less. NiMH could deliver more.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
