MEXICOWANDERER
Feb 26, 2016Explorer
When the field / armature / solenoid / electromagnetics collapse it puts on a real show on an oscilloscope screen. Measure both the starter motor connection, then on the battery supply voltage of the solenoid connection. Watch for peak inverse voltage as well. A stout avalanche rectifier will greatly mute the battery side hysterics. I've cooked a number of Motorola MR2535 rectifiers doing this on the starter motor side of the solenoid.
A gear-reduction type starter motor significantly reduces peak current cranking amperage) values.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
