Salvo
Feb 27, 2016Explorer
You guys got it right. The dynamic loading of the starter motor, created by piston compression is causing the current gyrations.
I think most if not all new cars have the ignition switch turn on a relay which in turn activates the starter solenoid. A lot less current goes through the ignition switch. On my new Miata, there's no key for ignition. Just a push button switch. The "key" is left in my pocket. The car doesn't use a key.
On a side note, automotive relays don't use a despiking diode any more. A resistor in parallel with the coil is now used. It allows the contacts to switch faster.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
