ib516
Sep 24, 2013Explorer II
Battery cut off switch
I just bought one like the one in the picture below. Should I install it on the positive terminal or the negative and why? I run two 12V group 27s in parallel.
Learjet wrote:
...If you have the battery disconnected and then plug in the trailer the disconnected end will be powered by the converter. If that loose end contacts the frame you can create a short....
