ib516
Sep 24, 2013Explorer II
Battery cut off switch
I just bought one like the one in the picture below. Should I install it on the positive terminal or the negative and why? I run two 12V group 27s in parallel.
beemerphile1 wrote:The breakaway needs to be wired directly to the battery to function. If it's wired after the switch - regardless of whether the switch is on the pos or neg, it won't work with the switch off. If the switch is on the neg, then the breakaway needs to go to the battery negative directly before the switch. The problem with that is where the negative is tied to the frame. If your breakaway uses the frame as its ground, then tying the breakaway negative to the battery negative before the switch will try to power anything else connected to the frame - regardless of whether the switch is on or off. I'd put the switch on the positive, but if your breakaway design used an isolated ground, it would be perfectly fine to run that ground before the switch and put the switch on the negative after that connection point.
If the switch is in the ground/negative, someday, someone, somewhere will tow the trailer with the switch open and the breakaway system will not be functional.
