ib516Explorer IISep 24, 2013Battery cut off switchI just bought one like the one in the picture below. Should I install it on the positive terminal or the negative and why? I run two 12V group 27s in parallel.Show More
time2rollNomadSep 25, 2013I stick with the existing convention of all switches, fuses, breakers placed on the positive side(DC) or hot side(AC) of the circuit.Only reason to place on the negative is to reduce risk of a short to ground when servicing the battery or other items close by.When removing a battery cable for service it is best to remove the negative side first.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
Related ContentBattery & cut off switchbattery cut off switchBattery Cut Off SwitchSwitching toiletsAutimatic Transfer Switch?
