ib516
Sep 24, 2013Explorer II
Battery cut off switch
I just bought one like the one in the picture below. Should I install it on the positive terminal or the negative and why? I run two 12V group 27s in parallel.
Learjet wrote:beemerphile1 wrote:
Why would there be a loose end anywhere? The topic is about where to locate a disconnect switch.
Doesn't the pictured battery discconnect in question come apart? If so, then there is your loose end and is on topic with the Op's post.
