We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
Usually landing gear, slide rooms, electric tongue jacks and that SORT of equipment are wired directly to the battery with a fuse or fusible link in the line. Those TYPE of items rarely draw any power unless you are actually using them.
