We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
ZERO should work with the switch shut off except solar panel maintenance charging of the battery. Not a single light bulb, pump, indicator light, landing gear, NADA! Just like unplugging and ripping the battery out by its roots.
Just like a circuit breaker. "It disconnects everything except the part that catches fire".
