We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
Pull the battery and charge it, knock off the surface charge and load test it. The dealers usually install the battery, who knows what they put in your unit. It may be kaput and not holding a charge, mimicking a draw.
