We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
Motor homes usually have two batteries.. Chassis and House, some of the systems you listed may be hooked to the other battery (Jacks are on my house).
Some may, as the other poster suggested, bypass the battery cut off. Same with the Propane detector, it may bypass, and the converter may bypass (or not) (Of course this charges the battery)
If you have an Inverter, it likely bypasses the switch.
Beyond that I'd need hands on to determine anything.
