We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
If you think you got a parasitic draw that can be checked by soldering up ap 12V light bulb and disconnecting the + batt terminal and hooking the light bulb between the batt post and the disconnected lead.
If that is as sort of weak flashy spark when you reconnect the batt, I have found that that does not necessarily mean a draw - maybe just charging up capacitors and stuff like that.
