We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
Not sure what battery turn off switch you are referring to. The one in the battery compartment kills everything. The one most likely found on your dash, sometimes referred to as the salesman's switch turns off all 12volt system EXCEPT the reefer control system on most coaches.
