We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
A draw like that with the switch open and you are not running the jacks or slide, could be the usual suspects:
A. you have pulled out the breakaway brake switch and your battery has the brakes fully on. If so put the pin back in--do not try to tow the trailer like that! If so and it has been on for a while, have the brakes inspected (magnets etc).
B. tank heaters left on by mistake --might or might not be via disconnect switch though.
