We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable th...
Well found problem. The emergency brake controller at hitch I would disconnect there when unhooking trailer and leave out. What that does is put constant 12 volts to brakes even with battery switch off. Well live and learn. :S
