Sam_Spade
May 16, 2016Explorer
Gjac wrote:
In your picture you can see 2 large nuts and two small nuts, there should be 12+v across the two large nuts if it is working
Unfortunate wording.
You should see 12V ON both lugs if it is working. (Exactly the same voltage.)
Seeing 12 V ACROSS the two lugs means something quite different.
