Chris_Bryant
May 16, 2016Explorer II
That is the right solenoid. The only other test is voltage at the third small terminal- could have two small terminals, one would be ground then. That is an intermittent duty solenoid, but the controller cuts the hold voltage down, so you won't get full voltage at the small terminal all the time.
