Chris_Bryant
May 17, 2016Explorer II
Moffittclan wrote:
can I jumper from the battery directly to one of the smaller terminals to test the solenoid? If I understand them correctly, applying voltage to one of the small terminals (the one NOT the ground) should engage the solenoid and I should hear it click...If it does click, then my problem would be somewhere else (like the ignition sensing circuit or something)???
Sound about right?
Yes- I would certainly disconnect the wire on it, then jumper it, though on the schematics I found the aux start switch does just that- jumps full power to the relay (solenoid).
