CA_Traveler
May 28, 2016Explorer III
Yes.
It may be wired as intended by the mfg. It's common for the salesman switch to not disconnect everything. And my manual disconnect switches also don't disconnect everything on either battery bank.
I did install a disconnect switch on the house battery negative terminal and will probably do the same on the chassis batteries.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
