Snowman9000
Sep 07, 2013Explorer
Disconnecting positive instead of negative at battery
This is actually a dinghy question but it needs tech answers, not towing answers.
It seems like a stupid question. But I am a master at overlooking obvious facts, so I want to ask to be sure.
On various Ford cars, to get them ready to tow behind a MH, one of the steps is to disconnect the negative terminal at the battery. This is not to prevent battery run-down, it is to prevent the electrically clutched "automatic gearbox" transmission from shifting out of neutral. So it is important to completely disconnect the battery, and not try to pull fuses instead.
The negative post is difficult to access. Very difficult. The chassis ground end of the cable is easy to access, but unfortunately there are other negative wires coming off the battery, so disconnecting the main negative ground is not enough. So to disconnect the negative at the post, you have to work in a tight space. But the positive post is very easy to access.
Now then, from working on cars, I know that the reason you disconnect the negative before the positive is for safety. If your wrench touches any metal, nothing happens. OTOH if you remove the positive first, and your wrench touches metal, you have sparks and a short circuit.
But if I was to install a disconnect switch on the positive side, properly isolated, it will be good, won't it? I mean, the battery is just as surely disconnected by a switch at the positive as at the negative. ??? Like I said, I feel stupid asking this, but it's cheaper than a transmission. :)
