ksg5000
Aug 22, 2020Explorer II
Might consider replaying the relay - there not that expensive. In my rig there are two solenoid/relays. One is a latching battery disconnect intellitec relay which has two fuses ... the other is std solenoid used to combine/disconnect chassis/coach batteries based on the position of the ignition key.
