CA_Traveler
Apr 26, 2023Explorer III
Use a ammeter to jump the fuse and check the amps. Some ammeters will measure the maximum amp draw. At the same time measure the voltage.
When you jump the solenoid and then remove the wires, does the solenoid stay latched as it should? Beginning to wonder it it's the solenoid.
You might want to get help and one option is to completely bypass the solenoid for your trip. I wouldn't just jump it for the trip.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
