jdrocci's avatar
jdrocci
Battery Disconnect Solenoid Fuse
2005 Holiday Rambler Ambassador 40PLQ
Under the driver seat on the outside is a compartment with a box that contains the battery disconnect solenoid. This solenoid has a nominal 5A fuse in the actuator circuit. Several times, I've lost all DC power to the house and found the cause to be this fuse. The last time it happened, I replaced the fuse with a 10A unit. Yesterday, with the MH parked in my driveway on shore power and the AC running, I locked up the unit and went inside my residence for the evening. This morning when I opened the MH for the day, I found all 12VDC circuits dead and the solenoid fuse blown again, This seems to have happened with no known stimulus.
Is this kind of failure well-known and if so, how/why does it happen?
Joe
  • I found a schematic and mine is magnetically held but there are multiple other solenoids next to it. I haven't found a wiring schematic. 2003 tioga 31n
  • did you pull the switch out of wall. It should have six terminals with a jumper diagonally across two corners.
    Center two should have the 12-volts across them.
  • Would you post the exact model number of the relay and not RV Elite number?
    Also the schematic you found.
    Please post a pic of those solenoids. The easiest way to determine WHICH of those solenoids is the battery disconnect is to use a 10 gauge jumper wire and connect the 2 large side posts together. IF the battery system gets power to the interior of the RV, THAT is your disconnect solenoid.
    Also, the solenoid, does it have 2 LARGE side posts and 1 center small post or 2 large and 2 small posts. Doug
  • Battery disconnect relays are almost always a "Latching Relay" only monetarily powered to close it or open it,
    The emergency start relay which connects house batteries to start battery, for emg self jump start, is always open unless you hold the emg start button closed, it stays engaged as long as you hold/push the button, any schematic will show electrical control wires going to each type of relay,
    But the schematic doesn't describe how that relay operates, for that info you have look up the part number and description of how it works, unless you already have that knowledge and experience ,
    By definition a relay is a power control switching device and all operate from electrical power, but some relays only need momentary power to open or close and stay in that condition until the next command pulse which will reverse the condition, others have built in time delay and open or close only after the timer has run its course snd completed its cycle, those are used in machinery control and not RV battery disconnect
  • This one is magnetic. I have jumped the 10 gauge wires and that works but obviously not a great solution. I almost connected those two with a switch and was going to deal with it like that but I want it working and that doesn't seem safe.
    https://rveliteparts.com/products/rev-rv-10101358-battery-disconnect-solenoid?utm_source=google&utm_medium=shopping&utm_campaign=high_performers&gad=1&gclid=CjwKCAjwxr2iBhBJEiwAdXECw_bhfK4Z_Xc0JEniBl7UvKwZqtVs0VtFAyMFyi6Cy9iA1QxS8QoCHhoCH0kQAvD_BwE
  • I think I need to switch out the solenoid but am hoping it is nothing else. The switch is not it and if jumped for a second correctly, it latches to on. + to + and - to -.
  • RV lite is a supplier of RV custom products part number RVCV1002. RVC- 1002Appears to be a magnetically held relay
    Before throwing money at it, disconnect small wires from relay ant try it again. If fuse blows, then issue is switch or wiring.
    Fuse doesn't blow it is in relay.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
