Eye75South's avatar
Eye75South
Battery Disconnect stopped working
There is a battery disconnect toggle switch next to the side-entry door to coach that use to make a clicking noise and shut everything off.
This switched stopped making a clicking noise recently and the power is currently stuck in the on position. I have checked the coach fuses and all are good.
There is a small metal box next to the batteries under the entry steps that I assume is the disconnect solenoid with power running through it.
Does this need to be replaced? If so, where do I find one? Are there any other steps I can try before spending more money. I have had the RV for less than a week but this just occurred as it functioned fine until yesterday.
Thank you for your help
  • It could be the switch, or a bad ground. You need a volt meter and know how to check things.
    I seldom turn ours off.
  • Thank you for the reply.
    The coach batteries are charged. The disconnect switch still does not function.
    Anyone else have any ideas?
    Thanks!
