ken56
Feb 06, 2021Explorer
Not uncommon for the charging side of the converter to die. Mine did. You need to access your converter and check the fuses on the back of it. Check the charging output by connecting a voltmeter to the disconnected battery cables when plugged into shore power. If you still have the original WFCO converter you may just want to cut to the chase and upgrade it to a newer 4 stage charger converter.
I didn't read your whole post...so....never mind. sorry.
