wrgrs50s
Mar 07, 2019Explorer
The only time it's beneficial to turn it off is when you store the RV and dont have power available to keep the battery on charge. Otherwise the battery will go dead within a few days if left on from the radio, propane leak detector, etc. that draw from the 12v battery.
Assuming you have a TT or 5th Wheel, I see no reason to set it to disconnect while towing as the umbillical cord hooked to the truck will continue to charge the battery while your fridge is on.
