fj12ryder
Mar 07, 2019Explorer III
Our trailer has a disconnect switch right on the cabinet down low. Unfortunately that a misnomer as some things don't shut off. The carbon monoxide detector and the radio/dvd player aren't disconnected. So even though you would think the disconnect switch would disconnect the battery from everything, you'd be wrong. I installed a manual switch on the battery that disconnects everything from the battery. I use it when the trailer is in short term storage.
Having the battery disconnected while traveling is fairly foolish as your brakes will not engage when the Break Away cable is pulled.
