ronmc's avatar
ronmc
Battery Disconnect?
On reading info. on battery disconnect, it says to disconnect battery if it will be on converter power for extended time.Anyone do this? Mine stays on shore power/ converter power for months. Am I ruining my batteries?
  • Depends on the type of converter you have...
    If it has a "maintain" or "float" stage then it does not need to be disconnected.
    This "float" stage will maintain you batteries at full charge without "boiling" them or damaging them.
  • RoyB's avatar
    RoyB
    Explorer II
    If your 2002 trailer does not have the smart mode converter/charger chances are you may be boiling out your battery fluids over time. They don't do well with a constant 13.6VDC voltage on them for long periods of time.
    If you leave it connected just be sure to keep a close check on the battery fluids...
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
