rollexx's avatar
rollexx
Battery disconnect
Picked up a battery disconnect for our fifth wheel. It's the paddle type that connects to
the negative battery post. Our trailer has two 12V batteries wired together.
I asked the guy at camping world if by installing this switch on one battery would it cut both batteries off. He said yes.
Well after installing I still get 12V power to 12V systems. Can only get power off by disconnecting a wire on second battery. Do I really need a switch for both batteries or am I doing something wrong? Thanks
  • A battery has 6 cells connected together in series with only two external posts.
    Similarly, Think of two batteries connected together in parallel as a single battery or box. One wire coming out to ground, another wire to positive. A switch on either wire would isolate the whole double battery. One of the wires will come directly from a battery post so the aforementioned disconnect could be attached to that post.
    However, that post will have a second wire on it, going to the same polarity post on the other battery. Could be tricky getting the wire and the switch on the same post.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
