Carlos___Ranae's avatar
Dec 08, 2017
Battery disconnect
We have a 2017 Jayco Seismic toy hauler 4212. I turned off the battery disconnect but the lights inside stay on. We then turned off the circuit breakers and still the lights are on. Is there another switch? Can the battery disconnect be malfunctioning?
It is solar prep but we have not installed solar. Whenever we use it after storage, the batteries (4) are completely discharged. If anyone can recommend a particular solar panel to keep the batteries charged while in storage it will be really appreciated.
❚ Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
