jayw900
Aug 10, 2016Explorer
Benaroo wrote:
Hi,
First point, the batteries were working fine until the recent service with the wiring changes. Batteries were at 98 percent when the trailer was dropped off but got them back from the service at 56 percent when I checked today.
Been charging batteries with 120 house power, converter has been running hard and non-stop for 4 hours, batteries went up to 76 percent charge, with the converter amp draw going down to 16 percent as the batteries get more charged.
I don't have a voltmeter and don't know how to use one, but I did check all the connections on the panel for the converter, they all were tight. The converter was very hot to the touch so I've unplugged the trailer from shore power and my digital tri-metric battery monitor says that the batteries are still at 76 percent charge.
when not plugged into 120 volt house power, no current draw from the converter.
"this was copy/pasted from another thread i posted in."
I read through most of this and people have suggested testing the voltages. It really is easy and i have some pictures for you to see how easy it is. The multimeter i got from sears for maybe 20-25 bucks and it's a very good investment, especially if you ask questions on here since people like Mex will want numbers for more accurate troubleshooting.
First link: Picture
This shows how to set the multimeter. Just make sure it is on Vac and -200- like in the picture.
Second link: Picture
This picture shows me testing an extension cord and the idea applies to outlets as well.
Third link: Picture
This one shows the tester leads switched around.
Hope these help you out.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
