BFL13
Oct 09, 2020Explorer II
time2roll wrote:
You need to compare the actual peukert function for each battery. As the internal resistance drops there is much lower effect due to high load. Also peukert is an exponential curve. Much lower effect at anything less than the 20 hour rate.
Came across this table in an AGM battery spec;
1 amp rate -125AH
100 hr -----118AH
20 hr-------105AH
10 hr-------100AH
so the rates for that are 1, 1.18, 5.25, 10
It looks like if you use half the 20 hr rate you would get maybe thrice the time? That's a lot.
Is that right?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
