I am plugged into 50 amp but my batteries are dying on both engine and motörhome have to put on generator every morning and recharge batteries with my towed any answers to what may be the cause ?????...
Check the converter/charger to see if it's working. While plugged into 120 volt power and with the batteries disconnected (remove the negative lead) measure voltage across the positive and negative leads AT the converter. Zero voltage means your converter is not working. If you don't disconnect the batteries, you will be reading the power from the batteries which will confuse the issue.
